Solved! Go to Solution.
Hi @Shavenuw
I'm afraid to say there is no real fix to get it back againother than hoping the next update brings back support. The last Android update seem to bring wifi calling to some handsets that were not officially supported by BT and took it away on others.
The only thing to check is that the APN settings have not change with the last update.
