Shaz64
Message 21 of 27
Re: WiFi issues on new mobile
BT have rung as I wasn't happy with the reply I had. They are saying that if it was an issue with my mobile then it wouldn't detect the other networks I connect to. Have suggested I back up and restore and reset network settings and then I'll have to re enter all the WiFi/password etc and it should allow me to connect in work. Will see when I go back in Wednesday. Does this sound like a plan to you?
gg30340
Message 22 of 27
Did you read my last post.
You have said that you are trying to connect to the BTWifi network at your work. If that is the case you need to do as I have stated in the post.
Shaz64
Message 23 of 27
BT are saying the BT WiFi app is nothing to do with this issue.
gg30340
Message 24 of 27
What is the name of the wireless network that you are connecting to at your work?
Shaz64
Message 25 of 27
Outfit
gg30340
Message 26 of 27
@Shaz64 wrote:
Outfit
So why did you say in message 19 "It is a BT WiFi but named on my phone if that makes sense".
I am out of ideas, good luck getting it sorted.
Shaz64
Message 27 of 27
Reset my networks, looking good but no cigar, searching for network. As soon as I clicked on WiFi it found the outfit name to connect but nothing even after resetting. Totally gobsmacked, BT are saying it's the router at work as I have no issues connecting at home or on mobile data. So disappointed
