Seamaster
Message 21 of 1,129
Re: Wifi Calling
Bound to happen sooner rather then later. It's in BT's interests to get as much traffic as possible off cellular and onto the fixed network.
jjphotos
Newbie
Message 22 of 1,129
Re: Wifi Calling
Where's the survey? We're with EE and would like to move to BT Mobile but I do find this feature very useful.
duncansby
Message 23 of 1,129
Re: Wifi Calling
Hi - the survey is now closed
lonetuber
Newbie
Message 24 of 1,129
Re: Wifi Calling
+1 For Wifi Calling on BT. Trying to decide what to do when my SIM only contract with BT ends in December as i am after a new phone, hope they hurry up otherwise i may have to use Vodafone as been struggling this past year with signal.
Meteosat
Message 25 of 1,129
Re: Wifi Calling
I have seen a number of comments on whether the HH6 might to capable of fentocel traffic, but I don't entirely understand this train of thought as O2 for example have their TU ap which allows messaging and voice calls over my BT BB connection just fine, without any modified routers or hubs. No doubt BT will roll out a solution soon and this excellent forum will be one of the first places to hear of it😀
Ansteyor
Message 26 of 1,129
Re: Wifi Calling
Wifi calling will enable you to make and recieve calls when you have no cell coverage (no mobile signal) but are within rage of wifi. So very useful if you are in an area with no mobile coverage but a wifi signal. BT smart talk only allows you to make calls using your home phone calling plan, via the app.
Meteosat
Message 27 of 1,129
Re: Wifi Calling
Yes, and O2 already do all of that on phones and Ipads via their ap regardless of the BB ISP!
Seamaster
Message 28 of 1,129
Re: Wifi Calling
Bound to be coming sooner or later.
clementscastle
Message 29 of 1,129
Re: Wifi Calling
I would like to stick my hand in the air and state I would be very pleased if wifi calling is implemented soon.
I have a work phone (BT Business) so can see that it will be very far down the line before I am able to receive any calls at home where the map says I should get at decent signal yet the phone says no, nothing, nowt.
Is there an email list I can subscribe to that would flag it up as soon as they did?
Mrs Clem
clementscastle
Message 30 of 1,129
Re: Wifi Calling
I think I have broken the thread. I cant delete this message for some reason....
