Message 11 of 14
Re: Wifi and 4G calling setup
Nothing works got the setting for WiFi calling I did a factory reset and it still doesn't work oh well thanks for all the help
Message 12 of 14
Using the EE APN found on another Wi-Fi calling post, I managed to get Wi-Fi calling on my Sim Free S9+ (bought from Argos on Pre-Order) but I have not got 4G Calling working.
Message 13 of 14
Do you have VoLTE switched on in Settings / Connections / Mobile networks / VoLTE calls?  I'm not sure if it's one of those settings that only appears if the network supports it, if so it might have defaulted to off when you switched APNs.
Message 14 of 14
I tried the EE APN on boot by putting an ID Mobile Sim in (which gave the VOLTE option to enable) and then put my BT sim back in and selected the EE APN on boot.
Doing that gave me Wi-Fi Calling but there's no option to enable VOLTE which I find strange as some people have done the exact same thing on a S8 and got it to work. I have the S9+.
