Lily2
Message 1 of 2
Wifi calling on pixel 3a
If I buy a google pixel 3a from the google store will I still be able to use Wi-fi calling on the device
1 REPLY 1
Bezman
Message 2 of 2
Re: Wifi calling on pixel 3a
I would say yes as the phone will come to you unlocked. I bought a different phone an unlocked moto g7 plus and put my BT sim in and Wi-fi calling and Volte both worked a treat. What i've found is if you have a really good 4g signal your phone will use Volte but if its bad it will use Wi-fi calling as long as you are connected to a wifi signal.
I hope this helps 👍
