Christine
Message 1 of 8
Will a Vodaphone mobile connect to BT WiFi Call?
Hi guys,
As per the title.
Will a Motorola G7 Power which is on the Vodaphone network connect to my BT Home Hub for free WiFi Calling?
Regards
Christine
7 REPLIES 7
Message 2 of 8
Re: Will a Vodaphone mobile connect to BT WiFi Call?
Hi @Christine   As long as you have WiFi Calling enabled on your Vodafone account then it should work on any WiFi network you are connected to including your BT Home Hub.
Christine
Message 3 of 8
So is it a special feature on a Vodaphone account?
I was hoping it just needed enabling on the mobile itself?
Regards
C
MZone
Message 4 of 8
I take it your asking if you can use Wi-fi calling on a Vodafone phone that has a BT SIM card in it?
Message 5 of 8
Hi @Christine
As previously asked. What exactly do you have e.g. A Vodafone locked phone and a Vodafone SIM (which is the only combination that will work) or a BT SIM in which case you need to ask Vodafone to unlock it. It needs to be out of Vodafone contract and/or they may charge you.
https://support.vodafone.co.uk/Using-our-network/Wi-Fi-Calling/1191069642/How-do-I-set-up-Wi-Fi-Call...
Christine
Message 6 of 8
Sorry for not being clear.
Vodafone locked Motorola G7 Power with a Vodafone pay monthly sim.
Will it work with a BT Hub and connect with wifi calling.
This is for my elderly mother who is only on the BT broadband lite 15gb plan.
BT offer a G7 with BT sim for £12 month including unlimited minutes, but when I try to buy for her just get message 'offers not available for lite users'
**Edited**
Regards
C
MZone
Message 7 of 8
Message 8 of 8
Hi @Christine
I refer to my previous answer, WiFi calling works on any WiFi network including BT so the simple answer to your question is yes.
It has to be enabled on the Vodafone account or phone and is only offered for certain Vodafone plans. You should read and check everything is OK on the Vodafone help pages. Note WiFi calling is charged the same as the mobile network and only useful if there is no mobile signal.
