Message 1 of 6
are 0344 and 0345 numbers free from BT mobile when you have unlimited calls
I have unlimited call plan, and just would just like confirming that 0344 / 0345 numbers are free. My searching suggests that they can be treated the same as 01 type numbers
5 REPLIES 5
Message 2 of 6
Re: are 0344 and 0345 numbers free from BT mobile when you have unlimited calls
provided they are standard landline numbers
https://www.bt.com/help/mobile/what-s-included-in-my-bt-mobile-allowance-and-what-isn-t-
Message 3 of 6
But how do I know if they are standard landline numbers when one number begins 0344 and the other begins 0345
confused ..... ?
Message 4 of 6
Many organisations use 03 numbers such as 0300, 0344 or 0345 as an alternative to more expensive 084 and 087 numbers. Calls to 03 numbers will cost no more than a call to a 01 or 02 number. This means calls to 01, 02 or 03 numbers will come out of your inclusive minutes.
from google search
Message 5 of 6
I must admit I though that 0344 numbers were chargeable even with unlimited or free minutes call tariffs.
Message 6 of 6
I ended up ringing BT mobile and was told that 0344 and 0345 numbers from a mobile are free as long as your calling plan has free minutes or unlimited,
