mrapriliafalco
Message 1 of 3
breaking contract
As BT are raising their prices yet again,if you leave BT on these conditions will you lose the £5 discount on your mobile bill for having broadband!!!!!
Your leaving due to their increases
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: breaking contract
Hi @mrapriliafalco and thanks for posting.
You need to have BT broadband to qualify for the discount so if you decided the cancel your services you would lose any discounts at that point.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
vipermo
Message 3 of 3
