revy32
Message 1 of 9
does anyone answer these problems on this forum?
Does anyone answer or even solve this problems on this BT forum?
8 REPLIES 8
pottyperson
Distinguished Guru
Distinguished Guru
Message 2 of 9
Re: does anyone answer these problems on this forum?
Sometimes, although it's rather dependent on knowing what the problem is.
RobbieMac
Moderator
Moderator
Message 3 of 9
Hi @revy32
Thanks for your post and welcome back!
If you could reply and let us know what problems you're having I'm sure we can help out.
Cheers,
Robbie
revy32
Message 4 of 9
very much like the post above, i have a nokia 7 plus but on the bt app it says 4g & wifi calling not supported but it is available on that phone.  i have android version 9 which is above the 7 required
RobbieMac
Moderator
Moderator
Message 5 of 9
Hi @revy32
Thanks for posting back!
You can use this link to see a list of compatible devices
I have had a quick scan of the list and it doesn't look like the Nokia 7 Plus is compatible I'm afraid.  There is also a section below on the link that explains how you can check if a handset is compatible.
Cheers,
Robbie
revy32
Message 6 of 9
Note: In order to use WiFi Calling, please make sure your Nokia 7 Plus is updated to Android 7.0 (Nougat).
mine is on version 9
imjolly
Message 7 of 9
there is nothing that says you cannot use wifi calling if your phone has it just your specific phone is not supported by BT for wifi calling - or have you phone somewhere where BT actually say your phone is supported?
revy32
Message 8 of 9
Ok, so my phone supports WiFi calling but BT don't recognise it does.
Thank u for the reply
Bloater
Message 9 of 9
There is a lack of BT support for Nokia phones, even though they supply them. The offical silence on this is deliberate, I believe.
