mark74
Message 1 of 5
euro data roaming?
hi after just returning from spain i was pleasaed i could use my data roaming while i was there, however it did not work can someone explain why this would be the case?
4 REPLIES 4
Fusionmoth
Message 2 of 5
Re: euro data roaming?
Is your roaming enabled on both your BT account and your handset?
Moderator
Moderator
Message 3 of 5
Hi @mark74 and thanks for posting.
How do I use BT Mobile abroad? might help. You can also get information at BT Mobile: How do I turn roaming on and off?
Cheers
David
mark74
Message 4 of 5
hi yes i did this and still nothing?
Moderator
Moderator
Message 5 of 5
@mark74 I'm sorry about that, if you get in touch with the Mobile team on this chat link they'll be able to get that investigated.
