Message 1 of 7
iPhone XS Not Compatible with Wi-Fi Calling
Hi Everyone,
Are there any clues as to why my iPhone XS is not compatible with Wi-Fi Calling and 4G Calling? They are enabled on the phone. IOS 13.0.
6 REPLIES 6
Distinguished Expert
Message 2 of 7
Re: iPhone XS Not Compatible with Wi-Fi Calling
Not sure.
It seems to take some time to update apps, after installing iOS 13.
Presumably you have deciphered the means of updating apps?
Give it a day, or so, and perhaps you may try a Power Down / Restart.
Don’t do a full reset!
Message 3 of 7
@Ribblelancs  Unfortunately it has never worked. It worked fine on my iPhone 6S but stopped when I upgraded to XS. I have tried all the usual things, restart, disable, re-enabled  etc. but has been like this for approaching a year. All Apps are up to date.
Message 4 of 7
I’ve had problems since updating to iOS 13 on an iPhone 8 Plus.
Connection to the wifi Call seems to struggle for several 10s of seconds, before the notification appears.
Is your 4g signal strong? It’s difficult to get a precise measure of signal strength on an Apple device. You need an Android phone for that, with an Application.
Perhaps you don’t need WiFi calling in the home?
Give it a while, then I’ll ask for assistance from the Mods........There’s been a lot of work in promoting WiFi Calling.   And it’s still a bit confusing.
albertj
Message 5 of 7
Strange,
The page for announcing this service - last updated 25th July 2019 says the following:
Spoiler
What phones does Wi-Fi Calling work on?
To use Wi-Fi Calling you will need a compatible handset.
All iPhone models from the 5S onwards will be compatible. This includes the iPhone 6, iPhone 6 Plus, iPhone SE, iPhone 7, iPhone 7 Plus, iPhone 8, iPhone 8 Plus and iPhone X.
https://home.bt.com/tech-gadgets/phones-tablets/what-is-wi-fi-calling-new-bt-mobile-service-will-boo...
It says '5S onwards' but yet only lists up to the iPhone X.
For some reason, it would seem incompatible - as this was last updated July of this year.
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
Message 6 of 7
@albertj@VeteranISPUser ,
It will probably work on the iPhone XS.
After some fiddling here today, the mobile signal is strong so Wi-fi calling is not needed.
If you go to settings > data options, check that the Wi-fi calling option is there. If it isn’t, then you are stuck!
Here: - the Wi-fi setting is there, but the phone doesn’t connect.....only to data connection.
When it does connect, it can take up to a minute for the display to show it, presumably as the data signal strength varies. Once connected it remains connected to Wi-fi calling ( if you are stationary).
Somehow the phone used 1MB of data in deciding - or that’s what MyBt says......not much to complain about.
Message 7 of 7
Interesting, it says BT WiFiCall (top left) on the notification screen but No and Not Compatible everywhere!
