userquery
Message 1 of 4
new BT mobile default SIM - not accepting 5555
Hi - I am having problems trying to set a new PIN on the SIM on my iPhone. When enabling a PIN for the SIM it asks for the current PIN and does not accept 5555.
Does anyone know the default PIN number for a personal BT SIM please?
I have one remaining chance to enter the PIN, help!
Thanks in advance.
Do I have to deliberately lock it out with three invalid attempts and then use my PUK code to unlock and reset it perhaps?
3 REPLIES 3
Keith_Beddoe
Message 2 of 4
Re: new BT mobile default SIM - not accepting 5555
@userquery
If you login to MyBT and look at your mobile details, I think you may find the unlock code there.
userquery
Message 3 of 4
thanks Keith, yes I can see the unlock code, but it is the PIN I was after.
Are you suggesting I use the PUK code instead of the PIN - I have tried that and it does not accept the PUK code entered on the PIN screen?
If I lockout the SIM PIN due to too many incorrect attempts, I presume I can unlock using the PUK (I hope) and would I then be able to set a PIN of my choosing?
Thanks for your help
Keith_Beddoe
Message 4 of 4
I think that is the idea.
