davidd15868
Newbie
Message 1 of 2
out of use BT sim in an old Alcatel onetouch
Hi All, need some help, I have been given an old Alcatel onetouch 1013, very basic mobile for my little one, however it had an out of use BT sim in which I have thrown away, only to discover that on turning it on again its now asking a Network key....this phone is old and ive factory reset after looking on the net..I have gotten the IMEI off the back but cant find a PUK generator...its old and I dont want to pay to get it unlocked...but I dont want to throw it out.
IMEI is **Edited**
thanks in advance
DD
1 REPLY 1
Message 2 of 2
Re: out of use BT sim in an old Alcatel onetouch
Welcome to this user forum.
You would probably find that if you put a replacement BT Mobile SIM card in it, it would probably work, if not, then BT Mobile should be able to help.
I expect it would be a standard  size SIM card, but BT Mobile supply on which will fit all phones.
