Tricia1865
Newbie
Message 1 of 5
received call data
i can see my received call data for 4 days only.  I need a number that called me a week ago.  How do I retrieve this?
4 REPLIES 4
Distinguished Guru
Distinguished Guru
Message 2 of 5
Re: received call data
It's probably a function of the phone rather than BT Mobile. If it's standard Android, open the phone app and select Call History. Mine shows all calls, in and out, back to August, but that might be less if there's a numerical limit and your phone is in constant use. If it's an iPhone I've no idea but someone else probably will.
Dean007
Recognised Expert
Message 3 of 5
HI @Tricia1865
Call list are stored on the handset, you will need to look on the device itself. Most devices including iPhones store numbers under called/recieved & Missed..
Tricia1865
Newbie
Message 4 of 5
Thanks I tried that but only shows last 4 days. I will check my iCloud backup.
Dean007
Recognised Expert
Message 5 of 5
Hi @Tricia1865
On iOS devices it can hold way more than that, I think its around 100 in total between the Recent/All & Recent Missed
