mluck
Message 1 of 3
transfer a number
How long does it usually take to transfer a mobile number to my BT sim?
Ordered  sim on 1st, received it on 3rd activated it right away and was told it takes 24 hours to transfer my old number.
I have the new sim, sent a PAC code , received a temporary number but still waiting for the transfer.
Getting a bit worried as no-one can get in touch with me as I still have this temporary number.
2 REPLIES 2
-Richie-
Guru
Message 2 of 3
Re: transfer a number
You can use the old sim from your old provider if needed, the number will still be active with them on the original number, once the switch takes place that sim will show no service, then insert the BT sim and it's done.
mluck
Message 3 of 3
Thank you for the advice, I have done as you suggested and put the old sim back in and it is now showing my number is active. I feel a lot better that my family can keep in touch.
Thank you again.
