davegarland
Newbie
Message 1 of 2
6036 an error has occurred SILVERLIGHT AMD Catalyst
I keep getting this error on my laptop when trying to access the Sports channels.
I have tried
Installing the older version of silverlight , disabling updates as advised by other users
Re-installing silverlight and using the Microsoft fix tool to repair the installation
Clicking and unclicking enable/disable hardware acceleration etc
To no avail - My laptop will not load the Sports channels.
I have tried tweeting to @btcare but all they suggest are things that I have tried and which do not work.
Will BT work on a fix for this ? It's completely frustrating !!
I read elsewhere that
http://msdn.microsoft.com/en-us/library/cc838192(v=vs.95).aspx#error_handling
"Graphics device's driver certificate is invalid."
My laptop's graphic card is using  AMD Catalyst 12.6
How can I convince the system that my certificate is valid if that is the issue ??
1 REPLY 1
davegarland
Newbie
Message 2 of 2
Re: 6036 an error has occurred SILVERLIGHT AMD Catalyst
I have just been into device manager to try and update my drivers but I am told that they are up to date by Windows 7 64 bit. SO why error 6036 .
ATI Mobility Radeon 4500/5100
