aphid
Message 1 of 3
Amazon Fire Stick remote and the Youview Amazon Video app
Will the Amazon Fire Stick remote control work to control the Amazon Video app on BT YouView box? Thinking of buying one to make navigation within the Amazon Video app easier.
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: Amazon Fire Stick remote and the Youview Amazon Video app
If you  running  the app/player  via your Youview box then the navigation and controls are via the Youview box so a remote controller designed for Amazon's  own device won't be effective on the Youview box.
aphid
Message 3 of 3
Many thanks. I didn't think it would but Amazon support seemed to suggest it would if I bought it. I know I would be able to return the remote if it didn't work but you would thing they would know already.
