Chris0109
Message 11 of 19
Re: BT App not showing on IPad
I'm not sure where you mean? Where do I find the option to 'restrict' on the right?
If this is in iPad settings, under which section?
If it is the App settings then I do not see any option to restrict.
Guru
Message 12 of 19
If you go into settings app, the screen will split into two. On the left hand side is now settings, on the right, general. About three quarters of the way down on the right is the option "restrictions". Is this on or off?
Chris0109
Message 13 of 19
Sorry, I'm not trying to be dumb but I simply don't see that? In settings in the App all I see is 'About', 'Feedback', 'General - to enable mobile streaming' and 'Accessibility' and this is in the center and not on a split screen.
Guru
Message 14 of 19
OK. What sotware version do you have.
Chris0109
Message 15 of 19
BT App version 1.1.5
IPad version 7.0.2 (11A501)
Guru
Message 16 of 19
Both of those are OK.
Guru
Message 17 of 19
Hi, the only two things I can find on the web are the restrictions have been switched on or try the reset button. Apart from that I have run out of ideas.
Chris0109
Message 18 of 19
Ok, still can't find the restrictions though but thanks for your help.....
Community Manager - Retired
Message 19 of 19
Hi Chris0109
The product team are not able to replicate the issue I'm afraid.
I did have a look myself and found lots of customers on the Apple community with the same problem, please take a look here, wonder if the advice on there might be more useful to you?
I am so sorry that we havent been able to provide you with any help, but looking at the Apple community it would seem that it has happened to more than a few customers with a selection of different apps.
If I can try anything else for you then please drop me a note.
Jacqui
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted Solution’.
