Micker
Message 1 of 4
BT SPORT HD 2
Hi
My BY SPORT HD 2 channel wont display and shows an error about connection.
Connection via ethernet is fine as all other HD Sports channels work perfectly including 4k.
BT Sport 2 works on my phone, just not on the BT box on TV.
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: BT SPORT HD 2
Hi @Micker Sorry you are having trouble with the BT Sport 2HD channel.
Has the channel worked OK before and this has just occurred or have you just activated the channel?
Have you checked all the cable connections to ensure that there is no loose connection?
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Micker
Message 3 of 4
Re: BT SPORT HD 2
Hi
It has never worked sd BT sport 2 is fine just hd bt sport 2 channel
Moderator
Moderator
Message 4 of 4
Re: BT SPORT HD 2
Hi @Micker Thanks for confirming that for me.
I'm not sure what the fault is here so please send us your details by clicking on my user name and selecting contact the mods and we will look into this further with you.
John
Kudos”
