aliballibee
Message 1 of 5
BT Sport App on Android Tablet - Activation after device reset
Evening
I had to factory reset my Samsung Android tablet tonight and reinstalled BT Sport App. We are BT fibre broadband customers and have this package.
Having reinstalled the app and successfully logged, in it's asking me to activate BT Sport again and asking for a PIN number, that was supplied in 2018.
I would have thought, having logged in, that the system should recognise the fact that we already activated this service?
We don't have a record of the 2018 PIN and I don't particularly want to wait a week for another one, given I was using the app yesterday. I also don't want a second activation, in case this causes more problems.
Anyway to quickly sort this?
Many thanks
4 REPLIES 4
Moderator
Moderator
Message 2 of 5
Re: BT Sport App on Android Tablet - Activation after device reset
Hi @aliballibee the pin is asked when you login with a BT ID that doesn't have account holder status claimed, account holder status can only be claimed against one ID. Do you have more that one BT ID?
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
aliballibee
Message 3 of 5
Thanks Neil
I was pretty sure the main account was the BT Sport login but I'll try one of the others tonight.
Cheers
Alan
aliballibee
Message 4 of 5
Hi - it's resolved now.
I changed the email to match that of my mobile account.
Thanks for your response.
Alan
Moderator
Moderator
Message 5 of 5
Hi @aliballibee,
Thank you for posting back, I'm glad you managed to get that sorted.
PaddyB
Community ModeratorPaddyB
Kudos”Kudos”
