Message 1 of 3
BT Sport - Choose stream quality
Is there a way that I can choose the stream quality? Netflix and many other apps have a low, medium and high option.
Tags (3)
2 REPLIES 2
Hunter2660
Recognised Expert
Message 2 of 3
Re: BT Sport - Choose stream quality
No it's "adaptive" and settles on the best quality for your broadband speed.
Message 3 of 3
Ok, they should make this available, many streaming apps have this option. Wifi it is fine but what if you are ussimg 4G, it will just eat through my data
