BobR6
Message 11 of 14
Re: BT Sport - Error code IPC6023
Thanks for getting back to me. Tried that yesterday and just tried it again leaving it off for much longer than a minute. Still no luck - same error message.
NeilO
Moderator
Moderator
Message 12 of 14
Thanks for trying that @BobR6 I'm sorry it didn't work. How is the BT TV box connected to your Hub? If you're using extenders can you try a reset on them?
If that doesn't help I've sent you a private message so you can get in touch and we'll be happy to get this looked into.
Neil
BobR6
Message 13 of 14
Hi Neil. Yes that worked for me too. Thanks for your help.
NeilO
Moderator
Moderator
Message 14 of 14
@BobR6 Nice 1, enjoy the football 👍
