melvino
Message 1 of 12
BT Sport Rugby
How can I disable the Timeline at the bottom of the screen when viewing rugby? I find it very distracting
11 REPLIES 11
DarrenDev
BT Sport Expert
Message 2 of 12
Re: BT Sport Rugby
Which platform/app are you watching it on?
melvino
Message 3 of 12
Re: BT Sport Rugby
App
Matt-S
Moderator-Retired
Message 4 of 12
Re: BT Sport Rugby
Hi @melvino,
It sounds like you are watching the game on the Enhanced Player if you switch to the Standard Player you won't see the timeline.
Normally it will ask you what Player you want to use when you load the stream.
Matt
melvino
Message 5 of 12
Re: BT Sport Rugby
Thanks. I'll give that a try!
melvino
Message 6 of 12
Re: BT Sport Rugby
Sadly - and annoyingly! - it's still there. No offer of Enhanced or Standard player, either - just immediate launch. Have tried unsuccessfully to find option for changing Settings.
Matt-S
Moderator-Retired
Message 7 of 12
Re: BT Sport Rugby
@melvino,
Can you try and uninstall and then reinstall the app from your mobile devices app store?
Matt
DarrenDev
BT Sport Expert
Message 8 of 12
Re: BT Sport Rugby
I think maybe we're misunderstanding what you mean by timeline @melvino
When you launch the enhanced player, there's a bar along the bottom of the screen that shows goals, cards, etc. Is that what you mean by timeline? That should go away just by tapping on the screen.
If that's not what you mean, please try to describe what video you're opening and what it is that you want to hide.
melvino
Message 9 of 12
Re: BT Sport Rugby
Yes, that is what I mean. Can be removed in small screen view by clicking on screen, as you describe, but not full screen
DarrenDev
BT Sport Expert
Message 10 of 12
Re: BT Sport Rugby
Are you using a phone? If you turn the phone on its side, does the video also rotate so that it fills the screen? Is this where you're saying the timeline won't go away?
