terrypward
Message 1 of 3
BT Sport UHD Subscription error
Hi
I had the engineer visit today for BT TV (Total Entertainment) and every channel works, apart from BT Sport Ultra HD.
I have the correct equipment - the UHD box and a compatible TV, but BT Sport UHD has a message that says I need to call BT to subscribe.
I have already subscribed, so assume a button needs to be pressed somewhere to turn it on... but the call centre helpline on the tv screen couldnt seem to figure it out. They told me to turn it off and on again, try playing a video from the on demand section and then finally that it will work at midnight. I'm not convinced.
Could a mod take a look please?
Terry
2 REPLIES 2
terrypward
Message 2 of 3
Re: BT Sport UHD Subscription error
All now sorted -  wasn't working this morning, but has started now.
Moderator
Moderator
Message 3 of 3
Hi Terryward,
Thank you for posting back. I am glad to hear that your UHD subscription is working Smiley Happy
Cheers
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
