Message 1 of 6
BT Sport Ultimate on BT Pro box
Just received a new BT Pro box to replace my previous UHD box. Connected to wifi and am watching football on the BT Sport Ultimate channel and the picture and sound keep stuttering. I never had this problem with the previous box which was connected via network extenders.
Anyone else having this issue and is there any way to solve it?
Tags (3)
5 REPLIES 5
Message 2 of 6
Re: BT Sport Ultimate on BT Pro box
I have the BT Pro box and also experience the stuttering. Apparently BT are looking into it.
If you press pause and resume this helps.
Message 3 of 6
Are you able to try an Ethernet connection to ensure the WiFi is up to it?
The Ultimate channel needs almost 30Mbps of continuous stream to work without issue.
I have the Pro Box streaming via WiFi here fine for channel 465.
Fibre 2 Unlimited using EE Smart Hub 2 with EE TV Box Pro (UHD/HDR) in IP mode.
Message 4 of 6
Just for info my BT Pro box stutters on all channels - terrestrial via aerial or networked.
Message 5 of 6
That is a different known issue - changing channel usually fixes it.
It it is just Ultimate stuttering then it is likely to be an Internet speed issue.
Message 6 of 6
I've gone back to ethernet (using the BT network extenders) and it works fine.  I had also tried the Sky channels and had the same issue with the sound/picture stuttering.  So it looks like, in my case, it's a wifi-specific issue.  The BT Pro box is approximately 5 yards from the BT hub, although there is a wall in between, but the wifi connection is strong.
