NeilO
Moderator
Moderator
Message 11 of 29
Re: BT Sport Ultimate on BT TV vs Apple 4K TV
@urbanlegend179 You can add it to the Now Big Sport and Now Sport packages for an extra £5 per month.
Neil
ozsat
Recognised Expert
Message 12 of 29
Not sure if it is still on but you could switch to VIP package for a month to get the new HDR box - then after a month drop down to sport only with HD add-on. This will still give you the 4K/HDR channel.
You need to take out a new contract I think though.
using Superfast Fibre 2 Unlimited with BT TV Box Pro (UHD/HDR).
Piotrch
Message 13 of 29
I know that new Xbox Series X will support 4K HDR but what about Atmos? Buying new Apple TV just to get Atmos is bit expensive. Thanks
Barisax18
Message 14 of 29
Does the 2021 Apple TV let me pause and rewind the action when watching BT Ultimate events in 4K/HDR?  If so it would be worth upgrading my Apple TV as my Amazon Firestick doesn't allow me to do this.
Piotrch
Message 15 of 29
Thats great question. If it’s like BBC  iPlayer then I say no. It’s comeback to 90s..
DarrenDev
BT Sport Expert
Message 16 of 29
It's not the device that adds this capability - we have to write it into our apps.
It's coming to all large screen apps soon, as part of "Pro Player" which was launched a couple of months ago.  No need to buy a new device.
Barisax18
Message 17 of 29
Thanks for your answer, I won’t waste my money. What is Pro Player? I can’t find any reference to it.
DarrenDev
BT Sport Expert
Message 18 of 29
The option to use it will appear during football matches. It shows a timeline of all the major events during the match, allowing you to jump straight to that point to watch it as a replay clip. During the entire match, you'll be able to skip back and forth as much as you want.
Piotrch
Message 19 of 29
Sky HDR ordered, BT Ultimate next month. It will be superb season.
How many HDR things will there be to watch next 30 days?
ozsat
Recognised Expert
Message 20 of 29
Boxing on BT Sport tomorrow is HDR.
