Evs5
Message 1 of 4
BT Sport in HD on Youview +
Hi,
I am having issues getting BT Sport in HD. Have taken the HD Extra bolt on and other extra HD channels work fine. I have made a number of calls to BT but still unable to sort.
Does anybody have any advice?
3 REPLIES 3
rarmitage124
Recognised Expert
Message 2 of 4
Re: BT Sport in HD on Youview +
Just to check, have you gone to channel 430 and pressed ok. What comes up?
If my post has been useful, please click on the Ratings star on the left-hand side of the post.
If I have answered your question correctly please let me know by clicking on ’Mark as Accepted Solution' Thanks
Evs5
Message 3 of 4
Thanks for the reply. Yes and get the message would like to set up this channel now? It then takes me to a static page saying phone this number, which I have.
rarmitage124
Recognised Expert
Message 4 of 4
Try live chat. Click here and they should be able to fix it for you
