Message 1 of 1
BT Sport on Amazon devices
Hi
I'm just wondering if there will ever be support for Amazon devices? They are so similar to Android and yet there is no Kindle Fire app, there is no Fire Stick app and you can't even go on a browser on the Fire Stick (e.g. Firefox) and log in to the BT site to try and watch video that way -it tells you you must use the app, which is of course on Google Play, not compatible with the Fire Stick. It's disappointing that there is no support for what is essentially one of the biggest mobile operating systems in the world!
Could the BT tech folks not remove the restriction on browsers on an Amazon device so that even if there is no app, it's still accessible via the website? If not I'd appreciate the technical explanation as to why it's not possible if someone has it?!
Thank you
