amanofkent
Message 1 of 3
BT Sport via PlusNet finding a TV not having to use comcast
I am currently looking to upgrade my TV and would welcome advice as to which TV suppliers/models can view BT sports without having to use comcast.
I am giving my TV to my son with the comcast connection so it would be helpful to find which TVs can run the BT sports app without having to buy another especially as I only use comcast for BT.
Many thanks for your help.
Martin
2 REPLIES 2
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: BT Sport via PlusNet finding a TV not having to use comcast
Not sure I understand the Comcast reference. Is this actually a Chromecast ? Or is it some cast facility of your current TV.
As far as I am aware the current situation is that there is no BT Sport app that exists on TVs  alone.
(BT TV  Customers may consider using the recently launched BT TV App Extra as an alternative large screen experience.)
amanofkent
Message 3 of 3
Thank you for your reply, yes I meant Chromecast. I believe you are correct that no TV has the BT Sports app, oh well at least that gives me a choice of all the TVs on the market. Thanks again.
