KennyR
Message 1 of 4
BT Sport,vision and TV
Does any body know if BT Sport,Vision and TV all require different usernames/passwords
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: BT Sport,vision and TV
Hi @KennyR,
To access the BT Sport and BT TV Apps you'll need the account holders BT ID username and password.
You can find out more here - Setting up the BT Sport App
TV on the go with the BT TV App and online player
I hope that helps?
PaddyB
KennyR
Message 3 of 4
Hi. Thanks for responding to my query.I know about having a user name,usually the BT ID but I wanted to know if a different password was required for each app but I have been having problems with passwords recently,especially getting BT Sport on my mobile
Moderator
Moderator
Message 4 of 4
@KennyR Your BT ID will have only the one password. Is it possible that your mobile has stored an old password which is prefilled in the BT Sport app?
