Message 31 of 40
Re: BT Sports on Smart TV,Kindle Fire and PC
trying to view BT sports on a Philips SMART TV
Distinguished Guru
Message 32 of 40
Unless the TV will actually run Android apps, you'll need a settop box or similar device.
If not, I'll try again 🙂
Message 33 of 40
thanks
Sargan
Message 34 of 40
I reda you say App works .... what App ?
I have SMART TV and Bt BB, so keen to find out if there is an app (like iPlyer) that will allow me BT Sports
midsomerjambo
Message 35 of 40
In response to ray_dorset, one of the nice things you get with the Kindle Fire HD is a micro HDMI port. You connect one end to the Kindle and the other end to the TV HDMI port and Bob's your father's brother - whatever you see on the Kindle screen displays on the TV and my experience has been that the sound quality and video resolution is pretty good. So there's no need for a TV to run Android apps (no idea whether that's actually possible). BTW, the cable costs about £5.
Cheers, MSJ
stringerscales
Message 36 of 40
Hello Gullbo.
Want to watch BT Sport om my smart tv but have this same issue with silverlight. Am not very (at all) techy so don't really understand what the apk is that you refer to as a way round this. Could you give me some more information please as to what it is and what i do with it ? Thanks. Geoff.
stringerscales
Message 37 of 40
Hello Guilbo.
do you have link to download the apk file which you mention please ?
thanks.
geoff
oksnab
Message 38 of 40
hi any chance someone can pm or email me the ask file link as i  cant find it and still cant get btsport on my kindle thanks.
cufccufc
Newbie
Message 39 of 40
Hi what site do I go on for the download for the Kimble fire to watch btw sports cheers steve
Guru
Message 40 of 40
Hi, not available on the Kindle. "The Amazon Kindle Fire is not currently supported." http://bt.custhelp.com/app/answers/detail/a_id/44489/kw/bt%20sports%20app/c/6401,6459,7452/session/L... Stew
