Do you mean
Recognised Expert
Accepted Solution
BT Sports on laptop
I only have a laptop and am on adsl. I only have the basic broadband plus phone package.
As I read it all I need to do to get BT Sport on my laptop , from 1st August, is to go to BTSport.com and login using my existing MyBT login details. Any downloads will not count against my monthly usage.
Is it that simple or have I missed something.
Distinguished Guru
Re: BT Sports on laptop
Yep, that's itSmiley Happy
Though I did read somewhere that you need to install Microsoft Silverlight, but this may only be if you connect your laptop/PC to a TVSmiley Indifferent
-+-No longer a forum member-+-
Distinguished Guru
You need Silverlight just to watch. See the legal stuff at the bottom of this page.
You can click the white star next to this message if you think it was helpful.
Here are the minimum computer requirements from Microsofts Website:
ComponentsRequirement
WindowsX86 or x64 (64-bit mode support for IE only) 1.6-gigahertz (GHz) or higher processor with 512-MB of RAM
Macintosh (Intel-based)Intel Core Duo 1.83-gigahertz (GHz) or higher processor with 512-MB of RAM
There are browser requirements as well:
Here is the link:
http://www.microsoft.com/getsilverlight/Get-Started/Install/Default.aspx
All the best
Recognised Expert
Many thanks - already have Silverlight v5.1.20125.0 on lappy but have never used it. I would assume it will run automatically when required.
The requirement for silverlight is a pain. It completely rules out linux.
