Jazzman
Message 1 of 9
BT TV Android App Error Code GJ999
BT TV App Error Code GJ999
Hi
Issue: Cannot login to my BT TV android app. It always displays a GJ999 error code upon trying to login. It has been fine, up until now.
Device: Huawei P20 Pro with up-to-date android patches.
Things I have checked: -
* My email address is correct and my password is correct
* My BT ID login is set up
* My BT TV account is linked to my BT ID
* My BT ID account role is listed as 'Account Holder'
* Closed app and restarted on numerous occasions
* Cleared data and cache
* Uninstalled and reinstalled
* TV and Sport Tool page isn't loading - This page isn't working - support.bt.com didn't send any data - ERR_EMPTY_RESPONSE
* BT TV App is working fine on my iPad
* BT Sport app is working fine on my android
* I have BT Broadband Infinity 2 so I'm assuming I'm connected to fibre, although I'm sure it isn't fibre right up to my property. I believe it's only fibre up to the exchange. I'm not 100% sure, to be honest with you
Please advise as soon as possible, as there doesn't seem to be a lot of information regarding this error code. It would also appear that moderators usually request details to be sent to them via PM, upon invitation, naturally, iro this code.
TIA.
Best
Raymond
An ounce of prevention is worth more than a pound of cure...
8 REPLIES 8
Moderator
Moderator
Message 2 of 9
Re: BT TV Android App Error Code GJ999
Hi @Jazzman  welcome back and thanks for your post and details of all the checks you have carried out. Sorry that you are having this error with the App. I've sent you a Private message explaining how you can contact the forum moderation team and we will be happy to help you get this fixed.
Check here: https://community.bt.com/t5/notes/privatenotespage
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
Jazzman
Message 3 of 9
Thanks for your reply, John.
Will contact the Moderation Team a little later.
Raymond.
Moderator
Moderator
Message 4 of 9
Hi @Jazzman  thanks for sending over your details. I've passed them to our TV experts for their help to get this fixed for you. I'll keep you updated.
Cheers
John
Kudos”Kudos”
Moderator
Moderator
Message 5 of 9
Hi @Jazzman  the BT TV team believe they have fixed the fault with the App. Would you please test and see if all is ok now and post back to let me know how you get on.
cheers
John
Kudos”Kudos”
Moderator
Moderator
Message 6 of 9
Hi @Jazzman  I called earlier and left a brief message. Have you had a chance yet to test and see if the fault has been fixed?
thanks
John
Kudos”Kudos”
Jazzman
Message 7 of 9
Hello John
Thank you for your voicemail.
Yes, all is well, now. Would you please be so kind as to reply with the solution, so as to help other members of the forum with this pesky error message. I'd also like to know myself, as I have a very inquisitive mind.
Regards
Raymond
Moderator
Moderator
Message 8 of 9
Hi @Jazzman  thanks for checking that and getting back to me. The BT TV team checked and there was some conflicting information which was causing the err. They factory reset the App and asked for you to check and it worked ok then. 🙂
Cheers
John
Kudos”Kudos”
Jazzman
Message 9 of 9
Many thanks for you reply, John, and apologies for the tardy response.
It's a shame that there's no definitive solution for this particular error message that community members can resolve themselves.
Thanks again for your help.
Regards
Raymond
