rw1993
Message 11 of 17
Re: BT TV app picture problems on Amazon Fire TV 4K
Cool, thanks for letting me know!
Potbelly69
Message 12 of 17
today I am getting a constant choppy picture,4k stick on 4k tv have tried turning resolution down to 720p but no difference.
Works fine on pc but bought the stick for this reason 🤔
rw1993
Message 13 of 17
Hi
yeah mine randomly started doing the same again yesterday after months of working fine.
Phoned them up and explained and they were no help, and didn’t seem to even know what I was taking about so not really sure what the answer is. If you get anywhere let me know.
Mallett94
Expert
Message 14 of 17
Hardset the 4K Fire TV Stick to Max resolution at 50hz. But then also make sure you have Enable match content source frame rate enabled.
Hope this helps.
rw1993
Message 15 of 17
that doesn’t work and you can’t have match frame rate even on without automatic resolution. I also wouldn’t fancy watching something in that resolution either
Potbelly69
Message 16 of 17
Doesn’t work for me unfortunately 🤔
rw1993
Message 17 of 17
Seems to be working okay for me again.
