Ericthered61
Message 1 of 11
BT TV web player app
Hi All  ........ can any body help to download
I press the play on the programe required on trhe tv guide but it doesn't prompt me to download.
10 REPLIES 10
Distinguished Guru
Distinguished Guru
Message 2 of 11
Re: BT TV web player app
Hi @Ericthered61
welcome to the community
Can I clarify that it is this
http://bt.custhelp.com/app/answers/detail/a_id/62356/~/downloading-the-bt-tv-web-player-app
which you are attempting or expecting ?
or is it that you are expecting to be able to dowmload for later offline viewing  some BT TV content ?
I think  the bt web player app download is offered on the first access and can be declined or accepted - is it possible that the download was initially declined ?
Ericthered61
Message 3 of 11
Hi zulu17 ..... thanks for the reply, yes I think the link was declined but, have now decided to accept if that is possible.  is the a way?
Moderator
Moderator
Message 4 of 11
Hi @Ericthered61 Try Watch BT TV on the Go and you should be able to install the BTTV App from there.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
Distinguished Guru
Distinguished Guru
Message 5 of 11
Hi @JohnC2 I believe the link you've suggested only provides links  to download the BTTV app from Google Play and Apple App Store ,
I believe @Ericthered61 needs the Windows  BT Tv web player but having previously declined to install it is not seeing a prompt to install when selecting a BT Tv programme to play once they have  logged on to  BT TV on their browser.
Ericthered61
Message 6 of 11
Hi zulu17 ... yep, you are correct. Its for windows I need. Thanx
Moderator
Moderator
Message 7 of 11
Hi @Ericthered61 sorry about the confusion.
Can you try the following: log into your BTID and go to https://home.bt.com/ then go to the TV guide. Select the option to "Watch BT channels"  and select a program to watch and see if this gives you the pop up to install the player.
Cheers
John
Kudos”Kudos”
Ericthered61
Message 8 of 11
Hi John .... followed your instructions on selecting a programme it asks "watch now" have tried to click and double click on it nothing happens. Thanx Eric
Moderator
Moderator
Message 9 of 11
Hi @Ericthered61 I suggested that as I tried it myself but I was using a different browser to what I usually use. I've checked into this again and can you clear your cookies and cache and try again. It is very likely that there is a cookie stored that shows you have visited before and declined the download. Once you clear these it should think you are a new visitor to the site and offer the download option again.
Cheers
John
Kudos”Kudos”
Ericthered61
Message 10 of 11
Hi ... thanx to JohnC2 and zulu17 all sorted and up and running ... thanx again for your help.
