V_Meldrew
Recognised Expert
Message 11 of 39
Re: BT TV
@olleywrote:
Thank you its  v3.1.17
There's the problem,  I've just downloaded the latest version from https://www.player.bt.com/lib/BTTVPlayer.exe and it's only 1.0.0.36.
No Idea what you downloaded but it wasn't the BT TV App
olley
Message 12 of 39
Re: BT TV
Thanks again ,tried that , https://www.player.bt.com/lib/BTTVPlayer.exe,it went straight to uninstall bt tv player which I did and then a reinstall sill the same problem
address
https://www.player.bt.com/#/catchup/details/movida_18846?context=catchup-brandnewepisode%23JONSNOW&t...
followed by
There's been a problem
Sorry there's been a problem playing this programme, please re-start your browser and try again. (WP012)
Close this page
V_Meldrew
Recognised Expert
Message 13 of 39
Re: BT TV
What browser are you using?
It sounds as if there is a disconnect somewhere between your browser and the BT TV Player. try the following.
Use Task Manager to make sure there are no instances of the TV Player still running (i.e failed to shut down properly)
Launch Google Chrome browser and type https://tv.bt.com/tvguide into the address bar and login.
Click on 'Live TV' and select something to watch.
At this point one of two things should happen, either you will see a dialogue box asking if you have the BT TV player installed, if this is the case then check the tickbox (sorry can't remember the message alongside the tickbox). and click yes or OK whichever applies.
If no dialogue box appears then after a short delay the BT TV player should launch automatically and you should be asked to login again, another short delay and your programme should launch.
If that doesn't work then I'm all out of ideas.
Good Luck
olley
Message 14 of 39
Re: BT TV
thanks again no sill doesn't work ,has give me some more ideas will have a go tomorrow
V_Meldrew
Recognised Expert
Message 15 of 39
Re: BT TV
Did the BT TV Player launch as I described above?
olley
Message 16 of 39
Re: BT TV
yes goes though the steps you described ending with I am age or over 16 a pop-up box with program greyed out behind
Close this page
olley
Message 17 of 39
Re: BT TV
it even seems to show that I have been watching program when I try to open it again
Moderator
Moderator
Message 18 of 39
Re: BT TV
Hi @olley  welcome to the forum and thanks for posting. Sorry that you are unable to access the BTTV player and thanks @V_Meldrew  for trying to help you fix this. You have exhausted everything I can think of already. I've sent you a Private message explaining how you can contact the forum moderation team and we will look into what is causing this fault and get it fixed for you.
Check here: https://community.bt.com/t5/notes/privatenotespage
cheers
JohnC2
olley
Message 19 of 39
Re: BT TV
Thank you I'm really at the point of giving up ,completely baffled ,also forgot I had Microsoft looking at it remotely and they didn't understand it
V_Meldrew
Recognised Expert
Message 20 of 39
Re: BT TV
One last thought on this topic, try downloading ccleaner and check the registry for invalid entries and delete any found making sure you save your changes.
If you've never heard of it before, I've been using it for years and, with one exception a while ago when they had a virus in their repository, never had a problem with it.
