rarmitage124
Recognised Expert
Message 1 of 2
BT Vision Card Not Activating!
Hello Again!
After 5 weeks since my last post I have moved house and I can finally get ITV4 and the BT Sport channels.
The problem is that when I stick my card in the box it just does not activate. After an hour of waiting it just says "That activation is not completed" or words to that effect.
Please help, I would like to watch some football matches this season.
RArmitage
If my post has been useful, please click on the Ratings star on the left-hand side of the post.
If I have answered your question correctly please let me know by clicking on ’Mark as Accepted Solution' Thanks
Tags (2)
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT Vision Card Not Activating!
Hi rarmitage124,
Thanks for posting. Did you get this sorted yet? If not I can help. Drop me an email with the details. You'll get the 'contact us' form in the about me section of my profile.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
