jonmark
Message 1 of 2
BT Vision Silver Box with ESPN viewing card- can I get BT Sport?
I read somewhere that BT Sport will not work with a BT Vision Silver box.
Can someone confirm?  If so what are the options?
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: BT Vision Silver Box with ESPN viewing card- can I get BT Sport?
Upgrading to Infinity and getting them via Multicast or getting them via the aerial by getting a new Black box.
Although having said that it might work with a silver box.
Best bet is to either phone and ask or try to order the new channels online and it will tell you what options you have.
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
