I’ve just download the BT sport box office app and registered an account. When I go to sign in it says ‘this application is currently unavailable in your area’, how do I sort this?
Where abouts in the UK are you?
Hi, @Charlie1189 thanks for posting and welcome to the community. The app is only available from within the UK if you have a VPN or other type of software on your device that masks your IP address you'll need to disable it before opening the app.
Cheers
Neil
Hi @Charlie1189 do you have a VPN (virtual private network) on your device? If you do then you'll need to turn it off to use the app.
Neil
No I don’t which is why I don’t understand why I’m getting this problem
London, England
