Distinguished Guru
Distinguished Guru
Message 1 of 6
BT sport Help link in sticky
Don't know if its temporary problem or specific to me but the the link in SeanD's sticky fot BT Sports Help is currently repeatedly saying
The core node you are trying to access was not found, it may have been deleted. Please refresh your original page and try the operation again.
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: BT sport Help link in sticky
Hi zulu17,
Thanks for posting. I've checked that and it's working fine. Can you try refreshing the page?
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
Distinguished Guru
Message 3 of 6
Isn't working for me either.
http://community.bt.com/t5/forums/postpage/board-id/BT%20Sport%20Help
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Moderator
Moderator
Message 4 of 6
Thanks for posting guys. I'll get this looked into.
Cheers
David
Kudos”Kudos”
Moderator
Moderator
Message 5 of 6
Should be sorted now guys. Can you check and let me know?
Cheers
David
Kudos”Kudos”
Distinguished Guru
Message 6 of 6
Working 🙂
Helpful Post?
