gill68
Message 1 of 5
BT sport and sky multiroom
We have sky multi room which means we have 2 separate sky boxes connected to two televisions. Our main television is away at the doctors so I set up the sky box on the 2nd television to record BT sport and it tells me I do not have a subscription. We pay £22.00 a month for BT sport. Are we limited to one sky box. Also I cannot view it on my computer. Is this right?
4 REPLIES 4
NigelB72
Guru
Message 2 of 5
Re: BT sport and sky multiroom
I believe if you subscribe to BT Sport on Sky directly through BT, you have access to the app but if you choose to subscribe via Sky then you don't.
Will regards to Multiroom, I think you have to pay extra for additional box access.
iniltous
Guru
Message 3 of 5
In the short term, couldn’t you move the Sky card ( presuming you have Sky HD ) from the Sky box connected to the TV at the doctors, and replace the card in the multi room box with it, that way the BT Sport subscription is in that second TV box, if it’s Sky HD, when you subscribe to BT Sport over Sky you advise the Sky viewing card number to BT, that is the card that’s authorised to access BT Sport, when the poorly TV is back, swap the cards back
imjolly
Message 4 of 5
if you swap cards as suggested by @iniltous  you also have to pair the card to the 'new' sky box  this can be done at SKY online in your SKY account
VeteranISPUser
Recognised Expert
Message 5 of 5
I would have thought that swapping boxes would be the least hassle.
