MRCROM
Newbie
Message 1 of 2
BT sport on sky platform
Moving into a new property and Looking to buy BT broadband to include BT sport and have it on the sky platform but i have not yet had either installed, do i need to have the sky installed before the broadband so i can add BT sport straight away or can i get the broadband installed first and add BT sport to the sky platform at a later date once that is also installed?
thanks in advance for your help
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: BT sport on sky platform
If you are going to watch it on the SKY Platform you will need to have SKY Installed before you can order it because you will need the SKY viewing card number.
toekneem
(EASBF)
