Message 1 of 2
BT sport
Is there a way for me to watch BT sport without broadband and to watch through my iPad? I also don't have a by account
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT sport
Hi @Orourke_james1976,
In order to watch BT Sport online or through the App, you do need to have either BT Broadband or BT Mobile.
You can find out more here - How do I get BT Sport?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
