Message 21 of 107
Re: BTTV app on amazon firestick suddenly not working
i had that yesterday, did a re-tune and they came back
Message 22 of 107
Hi,
Is this still on track for a Tuesday update?
We have a fix that is now being tested. All being well, the update will be in the Amazon App Store on Tuesday. I'll update here as soon as it's available.
BT Sport Expert
Message 23 of 107
We'll know for sure on Monday. It definitely fixes this issue, but we need to be totally sure that it doesn't break anything else before we release it.
Message 24 of 107
Brtv app on firestick
Hi there. Last few days I'm getting an error code zs001 when I open the bttv app on firestick. I've. Been through all the settings and can't find reason why. Can anyone help?
Moderator
Moderator
Message 25 of 107
Re: Brtv app on firestick
Hi @Helengrant47 welcome to the community and thanks for posting. I'm sorry you're getting an error when trying to view the BT TB app on your firestick, I hope you don't mind I've moved your post to the correct thread on the community. As you can see from Darren's posts we're currently working on a fix so keep an eye out on this thread for any further updates.
Message 26 of 107
Ok thank you
BT Sport Expert
Message 27 of 107
I'm pleased to announce that the app update has passed all our testing, and is currently with Amazon for approval to release.  I would hope to see it available to install some time tomorrow (Tuesday 16th).  Thanks for bearing with us on this, and apologies for the inconvenience it has caused.
Message 28 of 107
Aww brilliant Darren. Thanks so much. Hope it works as I've missed my bt fix at nights 😂
Message 29 of 107
Is there any update on this as just installed on my amazon fire stick and was greeted with the error
Message 30 of 107
Hi ,I have just updated my firestick and it's still showing a security issue.
