GarryJ
Message 11 of 13
Re: BTTV on Amazon Fire Stick Problem
Hi Simon!
Yes, I came across the same software/upgrade prompt that had suddenly appeared, all working fine now!
All the Best
Garry
SimonSR
Message 12 of 13
Good news - problem solved it seems...
PaulPants
Message 13 of 13
Hi, though your issue is fixed, what is the stream like?  I have a Youview box and also watch on a PC.  They stream fine, but the football streamed on New Years through my Firestick was not as smooth, clear or crisp
