sd99
Message 1 of 6
Bah - No BT Sport for me :'(
Well I've recently signed up and installed a BT line, with BT ADSL Broadband, BT TV Essentials via BT YouView - and I just contacted BT to see if I can receive [free] BT Sport for no extra cost.
The answer?  Yes, if...
I swap my YouView box (HDMI, iPlayer, itvPlayer, 4oD, Demand5, FreeviewHD) for a BT Vision box (HDMI, no catchup TV, no FreeviewHD).  Or, if...
I swap my £10 ADSL 17MB unlimited broadband for £10 Fibre (not unlimited - 10GB, and 1MB slower).
Marvellous.  I can either downgrade my TV, or downgrade my Internet.  For FREE!
I really don't understand *why* BT Infinity is required for BT YouView/Sport?  It's just an ethernet connection from the hub...
5 REPLIES 5
Message 2 of 6
Re: Bah - No BT Sport for me :'(
there is no 10gb limit package on infinity - that would be crazy package with a fibre connection
sd99
Message 3 of 6
You're right...  I've just checked the website.  BT advisor advised me incorrectly then...
Still doesn't explain why I can't get Sports though - 17MB is way fast enough, even for an HD stream.
To me it sounds like an excuse to force people into upgrading!
Distinguished Guru
Message 4 of 6
I think you were misinformed about catch-up TV as well.
The Vision+ box doesn't have it built into the EPG in the way Youview does, but it is available through the menu system. I believe Youview has more catch-up programmes available, but you have to put up with commercials. On the Vision+ box there are fewer programmes, but no commercials.
findo_gask
Message 5 of 6
Going to get a card in August. Have Youview box but also have a CAM in my TV. No reason BT card won't work ?
Distinguished Guru
Message 6 of 6
Unfortunately BT have never advertised the viewing cards as working in any device other than the BT Vision+ black box connected to BT broadband and with a valid BT TV subscription. So I suspect that would be a waste of £10.
They have said that you can view the BT Sport web streams on a smart TV connected to the BTHomeHub if (and it's a big if) the TV browser supports Microsoft Silverlight.
http://community.bt.com/t5/BT-Sport/BT-Sport-via-a-Smart-TV/m-p/870716
