Mopax
Message 1 of 5
Bt shows as unavailable
On the amazon fire stick, when I searched for BT sport, right next the shopping cart( where you click to download) it says unavailable. And yes I'm paying the extra for big screen.
Can someone please help me with that?
4 REPLIES 4
DarrenDev
BT Sport Expert
Message 2 of 5
Re: Bt shows as unavailable
Is your Amazon account registered with a UK address?
Are you in the UK?
Are you using a VPN?
Mopax
Message 3 of 5
Yes its register in UK, since the amazon prime doesnt transfers when you move from another country, we had to create a new one here. And not I'm not using vpn, I also try setting my location to UK through a vpn but still show as unavailable.
DarrenDev
BT Sport Expert
Message 4 of 5
Is your account linked to the amazon.co.uk store, rather than the amazon.com one?
Go to the Amazon web site and log in. Go to your account, select Content and Devices, select the Preferences menu, and then Country/Region Settings. Make sure it says "You are currently linked to shop on Amazon.co.uk"
Mopax
Message 5 of 5
Really thankful for your help
