Tri99s
Message 1 of 5
Bt sport disconnect
Whenever I go to channel 430 or any other bt sport channel it won't show a picture a d will disconnect from the Internet. As soon as I go back to a normal freeview channel it comes up connection restored. I am able to use apps fine on the youview box and other subscription channels work fine.
Please help
4 REPLIES 4
Laelri2
Message 2 of 5
Re: Bt sport disconnect
Are you connected by Ethernet or Mini connectors/Powerline adapters?
Do you know what you're currently getting on a hardwired broadband test in terms of broadband speed?
Tri99s
Message 3 of 5
Youview box is direct ethernet from router. I do use powerline elsewhere in the house and have tried removing them but to no luck. Getting a average download of 4mb. All other on demand works fine as does xbox
gomezz
Recognised Expert
Message 4 of 5
Has it ever worked properly or has it just started doing this?
Suggest you try rebooting both router and then Youview box.
Tri99s
Message 5 of 5
Yeah all worked fine until last week, then youview box broke so got a new one sent out. Which all works OK except bt sport
