clueless63
Message 1 of 7
Bt sport on bt broadband
Hi,
does anybody know if you can watch BT sport on standard BT broadband with a usage cap of 12mb per month. Thanks in advance or any help.
6 REPLIES 6
Moderator
Moderator
Message 2 of 7
Re: Bt sport on bt broadband
@clueless63 are you trying to watch BT sport on BT TV or via the web player/BT sport App?
clueless63
Message 3 of 7
Hi NeilO,
sorry I should have said. I'm wanting to watch BT sport On Tv via the youview+ box with a standard broadband package.
Moderator
Moderator
Message 4 of 7
@clueless63 it depends on a few factors, you can get BT sport on BT TV if the exchange is ADSL multicast enabled and your speed is fast enough. Your line also mustn't be eligible for BT Infinity.  Can you enter your telephone number on this checker and post the results ensuring to remove your number when you reply?
clueless63
Message 5 of 7
Hi neilO
This is what I got with the checker for my number.
Moderator
Moderator
Message 6 of 7
Hi @clueless63
As you can see from the top part of the checker, BT Infinity is available for your line.
You would need to upgrade to BT Infinity to be able to watch BT Sport on BT TV.
Cheers,
Robbie
clueless63
Message 7 of 7
Hi Robbiemac
Thanks for your reply.
