walace58
Message 1 of 3
Bt sport programmes catch up
Is catch up available for BT Sport programmes?
If so how to I find the programmes as I can not find anything on BT player?
If not , why not?
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: Bt sport programmes catch up
The BT Sport on demand/catch-up is found within the BT Player by selecting Library then BT Sport.
it is not listed under the Catch-up category.
walace58
Message 3 of 3
Thankyou very much, pity they made finding it a bit complicated!
Priot to your reply, I searched other posts and find that scrolling back to the live entry on the EPG gives catch up if clicked on , but appears to run the recording if it has been recorded?
walace58
